Sony VAIO VGN-N130G/W Notebook Logo
Posted on Aug 11, 2011
Sony vgn-sr510g bios - Sony VAIO VGN-N130G/W Notebook
NEED DRIVER BIOS J0030J4
Following is the link for BIOS R0035J4 for Sony VAIO VGN-C140G/B, its for Vista:
File: PHBSYS-01250016-US.EXE Date: 7/12/2007 Version: R0035J4 Size: 1.19 MB
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNC140G&upd_id=2837&os_group_id=10
3helpful
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Please advise how to reset the biose on vgn-s28gp,i try to find reset jumper but i did not find out please help. aqeel.
Not sure which key Sony used but the easiest way to reset the Bios for a laptop is to start teh computer and go straight to Bios and select to restore Default settings. All Bios setups ahve this option. It is normally the F2, Del, F10 or F12 key right after you see the initial splash screen after tuning the computer on. The only other option I can think of without tearing the system open would be to remove the power cord, the main battery and the Bios battery if you have access then put it all back. In some models you can remove teh covers from the hard drive or Ram on the bottom of the computer and get to the Bios battery to remove it. I know a lot of HP models have that so it may be an option with the Vaio.
1helpful
Need SONY VAIO VGN-FJ170B BIOS password reset method...Please help.
To reset the BIOS password on your Sony VAIO laptop read the information from this link.
I cant remember the bios password of my notebook model sony vaio vgn-a497xp
You can reset the BIOS password. To reset the BIOS password read the information from this link.
BIOS KOD RA LENE SZÜK SÉGEM EL VESZTETEM
hi marcel0414,
http://esupport.sony.com/perl/swu-list.pl?mdl=VGNN320E..
You can try this.
mastergani
2helpful
Install wrong bios on sony vaio laptop model vgn cr 353 so dont see anything in bios setup or some garbeg seen in bios cant acess bios
BIOS is gone...u need to change the BIOS IC or may be the full Motherboard...
the other option is to go to tech shop and "TRY" have ur BIOS flashed with the correct BIOS software...
1helpful
Sony vaio VGN-S56GP pawer on Bios password
Hello, I can unlock ANY  SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto [email protected] WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
1helpful
Bios on laptop
Its either F2 or F3, Sony vaion use them both.
During starup press one off them
Good luck
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
