THE 4T40 E 4T45 E AND 4T65 E THESE TRANSMISSIONS DONT HAVE A FILL TUBE WITH DIP STICK.THOSE TRANSMISSION VECHICLE HAS TO BE PUT ON A LIFT AND LEVEL. TRANSMISSION HAS A FLUID CHECK PLUG LOWER HOUSING TRANSMISSION JUST ABOVE THE OIL DRAIN PLUG.TO CHECK FLUID TRANSMISSION NEED TO BE OPERATING TEMPERATURE. WITH ENGINE RUNNING AND TRANSMISSION FLUID PLUG REMOVE IF TRANSMISSION FLUID POURS OUT. CHECK PLUG HOLE.YOU HAVE TOO MUCH TRANSMISSION FLUID IN TRANSMISSION.IF FLUID DONT DRIP OUT HOLE NEED TO ADD A PINT AT A TIME.IF FLUID DRIPS OUT SLOWLY FLUID CORRECT TO POUR TRANSMISSION IN TRANSMISSION RAISE HOOD LOOK ON TOP TRANSMISSION ON DRIVER SIDE FOR A RED VENT FILL PLUG.REMOVE PLUG USING A LONG LONG FUNNEL POUR TRANSMISSION FLUID IN THE VENT FILL PLUG HOLE.THIS VECHICLE THE DEALERSHIP HAS TO CHECK FLUID USING A LIFT.YOU CAN DO THIS JOB BUT IT WILL VERY DANGEROUS YOU CAN PUT CAR ON JACK STANDS WITH VECHICLE SITTING LEVEL. BUT THE DANGER PART COMES YOU HAVE TO SLIDE UNDER THE CAR WHILE ENGINE RUNNING TO CHECK FLUID.IF YOU DO THIS JOB HAVE FRIEND OR HELPER AROUND DONT WORK UNDER CAR BY YOUR SELF ALWAYS KEEP CELLUAR PHONE ON HAND FOR EMERGENCY.
SOURCE: 2002 Kia Spectra Transmission Fluid Check
located on driverside below the fuse box close to the firewal
SOURCE: location of transmission fluid indicator dipstick
Couldn't find mine either. It's not in the owners manual. Actually, I found out that it does not have one. According to VW Vortex, they check the fluid at the dealership by computer.
SOURCE: checking fluid in transmission
There is no dipstick on a manual transmission. On a manual tranny, you check the fluid by pulling the fill plug on the side of the transmission. The fluid is supposed to be even with the bottom of the fill plug hole. Gently stuck your finger in there and on a fully serviced trans. you will feel the fluid on your finger tip. On an auto transmission the dipstick is on the passenger side near the exhaust manifold close to the firewall. Also you fill the trans thru the dipstick. Make sure you use the proper fluid and the correct amount.22
SOURCE: no dipstick to put transmission fluid into
HI, this transmission is a sealed type. you will need to purchase a special tool from the dealership to fill this unit properly.
Contact the nearest Audi dealer for this fill tool.
Pull out the dipstick.
With the gearshift in Neutral or Park and the parking brake on, let your engine run. Be sure the engine is warm when you pull out the dipstick. (Don't turn off the engine.)
Check the fluid.
Dip the tip of your index finger into the fluid on the dipstick and rub the fluid between your finger and the tip of your thumb. The transmission fluid on the dipstick should be pinkish and almost clear. If it looks or smells burnt or has particles in it, have a mechanic drain and change the fluid.
Wipe the dipstick with a clean, lint-free rag; then reinsert it and pull it out again.
If the transmission fluid is clear but doesn't reach the "Full" line on the dipstick, use a funnel to pour just enough transmission fluid down the dipstick tube to reach the line. Don't overfill!
