SOURCE: Hi, my name is Johnny
Your TV has a bad panel. Your Panel needs replaced. Would be more cost effective to replace the TV.
SOURCE: tv blinks on and off at will
Dry solder joint on pcb most likely cause
Need someone with schematic to chase it down or someone with a set of test boards
No easy answer to this one
SOURCE: Element tv.. model # ELCHS261 stopped working
Change the input. There should be an "input" or "source" button on the remote and/or tv for choosing the source for signal display. Change it to one of the other options (try all of them).
SOURCE: Element Electronics 32" FULL HD
What exactly do you mean by goes silent? Does the screen turn off but you can still hear the audio? Please provide this info so that I can help you with your problem.
