The watt governor is inside of light assembly. it is a square black box. take this out and hook it direct, white wire to white wire, black wire to red wire. and this should solve the blinking lights. good-day!
hi Carl, looks like you are the resident hunter fan expert! can you tell me if it is possible to replace a 85112-04 hunter remote receiver with a 27208 hunter universal remote receiver? too many wires and the colors dont match.
the light governor or black box, is were the wires hook up to fan and the lights.blackbox should have a red wire and a white wire. remove this box, then hook it up direct. white wire to white wire, black wire to red wire. then you should be fine! here is technical support # for hunter fans, if you have another problem. 1-888-830-1326, may god bless and have a good day. the blackbox its what causes lights to blink. hunter fan governor part # is 98480-02.only replace with proper part, if you do not want to wire it direct. good-day!
i took the universal receiver back. It is basically for a fan without a remote from the factory. going to get the correct replacement from hunter.
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
SOURCE: Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
Hope this is what you need. God Bless.
SOURCE: Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
SOURCE: Hunter Fan Remote Control Part No. 85095-01:
I had the same problem. I found that the reverse button needs to be pressed really hard. It now works but I need to press that button really really hard.
SOURCE: I have the blinking light
This problem was posted on several sites, but this was the only one where I found both the cause of the problem and the solution. Mine is a Hunter 5 Minute Fan which came with no remote. And after about a month the two lights would blink together whenever I'd turn them on at the wall. So in case it helps for that type of fan or the same type of wiring arrangment here is what I did: POSITIVE SIDE: P1) Remove the light shade. P2) Remove the 3 screws that hold the cowel and lower the cowel. P3) Disconnect (pull apart) the black and red wire coupling. P4) Cut the coupling off of the black wire that comes up from the lights. P5) Strip off a quarter inch of jacket from that black wire. P6) Remove the wire nut that connects the black wire coming from the governor with the other black wire. P7) Re-use the wire nut to connect the black wire from step P5 with the other black wire from step P6. NEGATIVE SIDE: N1) Disconnect (pull apart) the white to white wire coupling. N2) Cut the coupling off of the white wire that comes up from the lights. N3) Strip off a quarter inch of jacket from that white wire. N4) Remove the wire nut that connects the white wire coming from the governor with three other white wires. N5) Set the governor aside (or just throw it away). N6) Re-use the wire nut to connect the white wire from step N3 with the other white wires from step N4. That's all, you're pretty much done! Turn on the power and test the light. If all is good, re-install the cowel and the light shade.
