Question about NorStar T7316E Corded Phone
We have a few Nortel Networks T7136E set. We mostly use a headset for incoming and outgoing calls. However; there is one phone set that when we try to use the handset instead of the headset, there is no dial tone. We tried the various bottons but the problem is still there. Could you let us know the solution? Thanks
5 Suggested Answers
SOURCE:
  • 9 Answers
SOURCE: Is there a way to password outgoing calls on Nortel t7316E phones
As I said its an involved process It would be easier to walk you through it on the phone Email me curtis@mytrucom.com. I would need to talk to you while you press buttons on a phone.
Posted on May 22, 2009
ynotphone
  • 192 Answers
SOURCE: is the nortel 7316 analog?
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Posted on Jun 16, 2009
  • 18 Answers
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C>  And there you go. Hope i didn't confuse you
Posted on Oct 02, 2009
SOURCE: how do i check my incoming & outgoing call
send details of incoming&outgoing calls of number 9440682355
Posted on Dec 21, 2010
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
How do I program the T7208 telephone to display incoming telephone numbers?
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Sep 30, 2014 | Nortel Networks T7208 Telephone
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
To remove call barring activation
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
May 28, 2011 | Nokia Handsfree For 6020, 6101, 6102...
How do i check my incoming & outgoing call history on nortel T7316E
Jul 29, 2010 | NorStar T7316E Corded Phone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
After I have entered user id and password and the
Are you using the installer password or the admin password?
Jun 18, 2009 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone Logo
63 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
