ereplacementparts or direct from Sunbeam are the best retailers of spares, but at that age, you best bet is to buy another as a parts machine from eBay.
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Sunbeam2386Sunbeam2386MixMaster Series 275 Watts StandMixer. Overall User Rating. 3.0. out of 5 ... 2386 Reviews & Articles. Sunbeam - Small Appliance Parts...retrevo.com/s/Sunbeam-2386-review-manual/id/952ci071/t/1-2
Pry of the dome shaped cover at the back - putting a flathead screwdriver under it witll work, note the plastic prongs on the inside of it below
Get a couple of screwdrivers to hold out th e prongs on the speed control ring and then prise it of by intserting a srewdiver in front of the ring
Now you can tighten the nut on the vertical bolt at the lower inside of the mixer using a small screwdriver to push the nut around till it is tight and then add some loctite (or nail polish) to stop it coming undone.
The tilt mechanism should now work. To reassemble align the off indicator on the top of the machine with the OFF on the speed control ring and push it back on. Push on the dome shaped cover and you are finished.
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
