Hi paigepatten,
If you don't have the manual, this is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
Place the watch face down on the cloth. This will help keep your watch from being scratched.
Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
Repeat Step 3 to remove any links needed to adjust the band properly.
Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
