Apple iPod MA446LL/A MP3 Player Logo
Posted on Aug 10, 2011
The ipod wont charge with any of the ipod plug in chargers also with the computer ipod cord. its also says please wait very low battery and it still wont turn on
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2619
Points
ONE OF THE USB ATTACHED TO THIS COMPUTER HAS MALFUNCTIONED
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
My ipod wont charge when i plug it in it say very low battery please wait and never gets off that screen
Try charging it in a wall charger first. You may need to buy a new battery for it. Check out ebay. Once you get it, the installation is straightforward. Ifixit has disassembly guides, and I think the battery may be solderless.
I had my iPod (5th Generation Late 2006, 30gb) plugged into my computer yesterday and my computer went to sleep (with my iPod still plugged in). I woke my computer up and then all my iPod would say was: ...
Try a manual reset by holding the center button and the play button together for at least 10-15 seconds, this should reset your iPod and should refresh the battery,
In future do not let your battery run flat completely always keep a charge, and lastly charge through a wall charger and not from the usb port,
good luck
2helpful
'please wait, very low battery' but not charging
Try to reformat it. It might be a virus or a bug.
Please wait very low battery
This is, clearly, a battery issue. Try restoring the iPod by following this article "http://support.apple.com/kb/HT1339". If your issue persists, then you might have to send the iPod in. It might cost you, if your iPod isn't within warranty.
My ipod wont charge
This is either a bad battery or bad battery connector Hope it just Battery.
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
2answers
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
2helpful
Ipod 30Gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Battery might be bad. well try another charger first.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
