Go to this link for diagram,, the part your looking for is part 70 and 71 , they are located on the gas valve itself, and the retaining bracket is just a cap that holds the coils in place and is easily removed, unplug the coils and slide them off, and slide the new ones on,, One has 2 prongs and the other 3 ,,, very easy job to complete , if you have any questions, feel free to reply to this feed and I'll help you more http://www.appliancepartspros.com/bd_whirpool_gas_dryer_parts.aspx
How to Replace a C.O.P. Type Ignition Coil?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-cop-type-ignition-coil.html
How to Replace an Ignition Coil
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-ignition-coil.html
How to Replace an Ignition Control Unit
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-ignition-control-unit.html
How to Replace an Ignition Wire Set
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-ignition-wire-set.html
How to Test Ignition Coil?
http://schematicsdiagram.blogspot.com/2011/12/how-to-test-ignition-coil.html
Engine not getting spark from distributor?
http://schematicsdiagram.blogspot.com/2011/12/engine-not-getting-spark-from.html
Cost to replace ignition coil?
http://technoanswers.blogspot.com/2012/01/cost-to-replace-ignition-coil.html
Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html
How to replace ignition coil for Toyota rav4?
http://technoanswers.blogspot.in/2012/02/how-to-replace-ignition-coil-for-toyota.html
These details will help.
Thanks.
