Question about Plantronics CS55 Wireless Headset
CS55 headset battery was dead (app 1 1/2 years of service). I replaced it and fully charged. Worked fine for 3 or 4 days. Now, won't charge. Tried the system reset and power cycle, no change. Any thoughts?
    Scholar:
  • 126 Answers
On your base there are the numbers 1-4. Put the # 1 in the 3 O'Clock position like a clock. Try putting the letters that are in the bottom on B.
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 18, 2011
SOURCE:
Afterglow Headset won't turn on.
The battery is shot. These aftermarkets sit on the shelves for a long time, probably because they aren't made very well, and tend to break not long after purchase.
Jan 02, 2013 | PDP PS3 - Bluetooth - Afterglow AP.3...
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
Sir, my phone is Samsung gts5233w. Since a week it has got some problem with its battery.The battery gets low after 1 day,when it is fully charged.also i cant find "POWER SAVING MODE" in my...
Jul 24, 2011 | Samsung Star GT-S5233 Cell Phone
I am using a plantronics headset that I use normally everyday but yesterday while talking to a customer it made a click noise and then cut off I picked up the head set and finished my conversation. I then...
We're had customers call with similar issues. First, make sure your compatibility dial is set properly (located on the side of the base). If set incorrectly, it will make your headset inoperable. If that doesn't fix your issue, try disconnecting and reconnecting the battery and then perform a subscription. Both steps can be found below:
How to Replace your Plantronics CS55 Battery
How to Subscribe your Plantronics CS55 Headset
Good Luck from Headsets Direct!
Apr 28, 2011 | Plantronics CS55 Wireless Headset
Same here. Appears to charge but won't turn on.
Most likely, the battery is dead, not holding charge. Have not beeb able to find info for a replacement battery.
Aug 19, 2009 | Motorola Mobility HT820 Wireless / Cable...
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Oct 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics CS55  Wireless Headset Logo
299 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
