SOURCE: Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
SOURCE: printing fades at bottom of page
Try to aline the printer head which you can find in printer property
or the new catrage me be an old stock
SOURCE: printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
SOURCE: HP PSC1410 wont print and shows offline
I had the same problem. This is what worked for me: I went to the HP website and downloaded the hp Print Diagnostic Utility. Found the problem and fixed it in no time (device manager I believe)... worked beautifully. Hope this helps :-)
SOURCE: hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
