SOURCE: JVC AV-36950 TV won't turn on
In this case wat u can do is try to Turn On the set without the memroy card inserted....
If still same Problem u can try replacing the batteries.......
If the set turns on without the Memory card replace the memory card....
Good Luck.....
SOURCE: Weight of TV...in order to select proper wall/ceiling mount
Quick solution:
Weigh yourself on a scale. If you can, pick up the TV and step on the scale again. The difference between the two readings is the weight of your TV.
SOURCE: I have a jvc AV-27850. Some of the plastic control
Sorry this things not in production anymore.Try Ebay.com might able to buy some body sell these refurbish part.
