SOURCE: LG DVD RW not reading dvd
If the problem is only with reading the DVD's seems you do not have a dvd decoder installed or an appropriate dvd player. Download vlcplayer it plays most of the file formats and has many codecs integrated within.
Click here to download
or go to:
http://www.videolan.org/
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
Note: clisk START>RUN>type"REGEDIT" and press enter.
SOURCE: LG GH22NS70 Super multi DVD Rewriter just used
Power cable attached, interface cable attached, (Dta cable), and the small audio cable attached, plus computer on, and Windows loaded.
Windows XP:
1) Click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) When Device Manager loads, left-click on the + sign to the left of - DVD/CD-ROM drives
7) Right-click on the name of the optical drive.
8) Left-click on Uninstall
A Microsoft 'squawk box' will come up,
"Warning you are about to uninstall this device"
It's okay. Click on OK.
Close all windows, go back to your desktop screen.
Turn the computer off normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute. Turn the computer back on.
You should get a pop-up out of the system tray, "Found new hardware", and perhaps another one will follow, "Found XXXX DVD drive"
No? Doesn't work?
Try using another 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The IDE harddrive shown, is just an example of a device that uses a 4-pin standard Peripheral power cable. Mistakenly referred to as a 'Molex' power cable)
Make sure the interface cable (Data cable) is plugged in tightly.
Regards,
joecoolvette
SOURCE: I recently had a problem relating to
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete if this driver package is not right
Close all open programs
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
if your computer came with a motherboard disk the drivers could be on it or you will need to download one
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
(be precise)don
