Behringer Control DJ Mixer BCD3000 Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not install my bcd2000 to windows 7. the hardware and softwere
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Aug 10, 2011
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2249804
Points
16163
Four things to check:
Sometimes you must leave the device disconnected while installing.
You must turn OFF ALL anti-virus, spyware, anti-adware, popup blockers during install.
Sometimes you have to do the install in SAFE MODE.
Make sure the driver you have is Win 7 compatible.
CTK810 smf converter fow windows 7
You need to get latest USB driver for Windows 7 (both 32bits and 64 bits available) at:
http://support.casio.com/en/support/download.php?cid=008&pid=20
I think the SMF converter though is a 32 bits application will work on windows 7 provided the correct USB driver has been installed.
1helpful
2answers
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Boss br 800 driver windows 7
Uninstall any HP device and try it. Then reinstall the HP device.
2helpful
2answers
Windows 7 64 can not install the driver
Windows 7 64Bit requires signed drivers. Try looking on vendor's website otherwise I am afraid you need to either get a new controller or disable this requirement (not supported by MS)
1helpful
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
2helpful
Windows 7 roland e 09 Can't connect to PC
go to the manufacturers web site and download the driver software for your pc version (mac os, 32 bit 64 bit) windows 32 bit osor 64 os you will find the drivers on theyre support page
Problem with the Gemini Sound Products Gemini CTRL-SIX USB/MIDI DJ Controller and Audio Interface It wont be detected by the computer's usb on WIndows 7
In the control panel, sounds and devices, check that the device is in each list under audio, voice, and hardware tabs and that your device is the default device. If NOT in the list, the CORRECT drivers are NOT installed or not properly installed.
I installed my new Roland SD-50 and all worked fine untill it turned off automatically (powersave mode was default). After that computer didn't find the canvas. I decided uninstall driver by hardwares...
You may have to coax it back by unplugging or even trying a different connector on the computer. It may have disabled the port due to a current spike. Using the devoce manager in the windows control panel, see if the port has been disabled. If necessary delete the device and tell it to seearch for new hardware.
1helpful
I have a new Casio CTK 810 and installed driver and smf converter but cannot make a connection with my laptop and desktop, both Vista 32 bit........
Yeah, had that problem too with Vista (I used a 64bit) but it should work in Vista (32 bit) with limitations and Windows 7 32 bit
for Vista
http://support.casio.com/information.php?rgn=5&cid=008&pid=114
for 7
http://support.casio.com/information.php?rgn=5&cid=008&pid=934
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
