SOURCE: I can't transfer files to upload pictures to my pc using usb cable
Go to Sony site and download the driver for your phone
http://ma3-origin.extranet.sonyericsson.com/drivers/
Step 1
Remove data cable from usb and put it into a different one
Step 2
Connect your phone to the computer with the cable and turn it on.
You might see "Found New Hardware" wizard. DON'T let Windows search for the driver; point it to the driver you just downloaded, and install the drive on your computer.
After the driver as installed you should be working 100%
SOURCE: Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
SOURCE: usb file transfer cable is not working
That is fake, Why?because if you do some research in the net you will see a product there named "Nintendo DS Lite Charger cable" and if you open it you will see there that the product was previously named USB "TRANSFER" cable but now changed to USB "CHARGER" cable.
SOURCE: Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
