Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Hi again..
In order to provide better solution ,would you please provide the answers of the following questions?
1.The model number of your recorder ?
2.Does it have built in tuner ?
3.Have you attached antenna to recorder ?
Than I will try to propose a solution...Thanks...
Dear Friend...I have finally download your Recorder`s user manual..As I have propose on my first message your recorder can record from different sources but you must select the right source during programming of recording at the beginning .Recording variations for many types of programs or situations.Before recording Selecting a disc according to purposes of use (DVD-RAM/ DVD-R/RW)
Setting for recording on a DVDR/RW disc in Video mode;
a..Recording a TV program (To record a TV program or cable program with
recorder tuner.)
b. Recording an external source
c. Programing a recording
AT THE BEGINNING YOU HAVE TO Press INPUT SELECT repeatedly to select a recording source.
To record a TV program currently being broadcast, follow the procedures of this chapter.
Preparation
• Load a DVD-RAM/R/RW disc into the recorder.
- Load a disc which has sufficient space available to record the program.
- Make sure the loaded disc is not write-protected.
• If you record on a DVD-R or a DVD-RW disc, set "DVD compatible mode" ( page 33) to "Main" or "SAP." In DVD-R/RW recording, "Off" setting is regarded as "Main."
• If you record on a DVD-R or DVD-RW disc, set "Aspect ratio(Video mode)" ( page 33) according to recording sources.
IN CONCLUSION IF YOU PROPERLY SELECT THE RECORDING SOURCE AT THE BEGINNING YOU WILL SUCCEED TO COMPLETE THE RECORDING PROCESS..OTHERWISE YOU WILL CONTINUE TO RECORD ONLY NOISE AND SNOW ..
I HOPE IT HELPS...MY REGARDS..
As soon as I turn on my DVD Recorder, the screen is full of snow and makes a noise. When I click "easy navi", the square with the words "title" underneath is all snow. Any other suggestions? Thank you
In answer to your questions:
1. Model D-KR4SU - 120V AC 60 Hz 21W - Manufactured 2/2005 CY
2. Built-In Tuner - I have checked spec sheet in owner's manual and it does not say anything about a built-in tuner. Don't all DVD recorders have this?
3. Have Cable - no antenna.
Thank you - leialoha7
