Click on computer and see in the list for the c drive what is there
if you see aviation set up .exe
click on that and a tag that says run , click on run
It it is not there, click on the start icon (bottom lh task bar) and in the search bar under the programs section, type in --aviation
if it is on the computer it be revealed in the drive and file /folder where it is
click on it and click on open or run
SOURCE: critical component is either missing or cannot start
Have you tried a soft reset or hard reset yet P ? How about a ROM update ? Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
SOURCE: hp ipaq hx2490b driver
You can download it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3378425&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=215348&prodSeriesId=421399
Kindly rate this as Fixya if it helped you!
Cheers!
ID
