Watches Logo
Posted on Sep 03, 2008
I Have An Athletic Works Watch,I've Lost Setting Instructions mod#AWO52
  • 2 more comments
  • boris5757 Sep 03, 2008
    it's Also Solar Powered
  • Anonymous Nov 07, 2008
    i cant get my alarm set
  • somanytopray Jan 04, 2009
    I have the same problem but my Athletic Works watch is model number V4543ATM or V377
  • Anonymous Apr 19, 2009
    I have t he same problem as boris5757....
A
Anonymous
1helpful
Can we have the instructions for this watch? Can’t see me to find online we and we can’t not do any d ungrateful with the new battery installed.
https://oureverydaylife.com/how-to-set-my-athletic-works-watch-12234179.html
No instructions are online for AW91-729 Walmart Athletic Works watch.
Article online that may help:
How to Set My Athletic Works Watch
by John Smith ; Updated September 28, 2017
Related Articles
How to Set Your Watch
How to Set Timex Watches
Freestyle Predator Watch Instructions
Swiss Military Watch Instructions
Wal-Mart sells affordable watches by the company Athletic Works. It's sometimes common to throw away the directions, only to discover later you can't figure out how to set the watch. The problem is that Athletic House doesn't have a website or any manual online, so you may have difficulty getting help unless you find someone who also has the watch.
There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
Press the start button to change minutes.
Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Press the reset button to switch to the date, starting with the month, and press start to change it.
Press reset one last time to switch from month to the day, and again press the start button to switch days.
Press the mode button to finish the changes.
Tips
Depending on which type of Athletic House watch you have, the buttons might be in different places. But the steps remain the same, regardless of button placement. If you have more questions about your watch, bring it to Wal-Mart and ask to see a manual.
About the Author
John Smith began writing back in 2003. Smith is a technology writer currently living in Lansing, Mich. His articles have appeared in online publications including PC World and IGN, where he specializes in mobile apps for both Android and iOS. How to Set My Athletic Works Watch
Jan 29, 2018 • The Watches
2helpful
Instructions for setting my moms casio wave cepter watch mod#4756,she lost them
here:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
1helpful
I have a Athletic works watch and I can't get it off military time.
When in the set time mode press the A button this will toggle between standard and military time. I had the same problem, dscovered it by trial and error, not in instructions.
13helpful
4answers
With time displayed:
Press lower right, then upper left.
6helpful
2answers
CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
2helpful
2answers
I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
http://www.ehow.com/how_4587869_set-aquatech-watch.html
Give it a try.
Clem S
Sep 23, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
