SOURCE: how do you tighten bolts
The caps are at the back of the toilet seat. Just under the cap cover are the bolts. You will need a meduim sized flat screw driver. Hold the nut on the bottom and use the screw driver to tighten.
The covers pry up with a small screw driver IF they are square.
If they are more circular with ears they rotate counter clockwise about 30 degrees, Then lift the lid off.
Please rate this response and Good Luck, Phil
SOURCE: Can not remove toilet seat from Kohler Rialto
to access the nut remove the tank lid, then go down and forward, its there.
SOURCE: My toilet is a kohler low profile. There is not a
Hacked off the old seat? You mean the closet flange that connects to the sewer pipe?
That's the part that has the bolts. They go up through the toilet base.
If you have just a straight sewer pipe now, you can connect a new closet flange to it.
1.Hardware stores sell a rubber sleeve. This sleeve fits over the cast iron, or copper, or plastic PVC pipe, and the new closet flange has a stem that fits down in the sleeve. There are two large hose clamps, that come with this rubber sleeve.
The rubber sleeve is an adapter. It adapts the 4 inch sewer pipe, down to the 3 inch stem on the closet flange. (Toilets are known as a 'Water Closet', hence the flange that the toilet bolts to, is a 'Closet Flange')
Whatever size of rubber sleeve you need to adapt two pipes together, they have it.
The new closet flange is made of PVC plastic.
(Poly Vinyl Chloride)
The flange itself is about 1/2 inch thick, and has provisions for bolts. (Use Toilet Bolts, and nuts)
Be sure the closet flange sits flush to the floor. The 1/2 inch thick rim of the flange, sits on top of the floor. The flange is then screwed to the floor with countersink head screws. The slots allow the bolts to just slip in.
IF, the flange Does Not sit level on the floor, and the area for the toilet base is not level, you need to make a flat, level surface!
Do Not half step this, or you'll have a toilet leak from now until the time you fix the floor!
Would appreciate it if you would rate my solution. If you have additional questions, state them by clicking on Additional Comments.
SOURCE: How do I get the old toilet seat fastener bolts
On top if you look closely you will se that where the hinge is you can lift up a plastic cap and see the top of the screw. From there you can remove screw. It should be a flat head screw.
Good Luck
SOURCE: I cannot tighten the toilet seat on my kohler 3386
Give Kohler a call AFTER you read the instructions thoroughly. Good Luck, seriously.
You will need to check the drainage fitting these toilets are draining into. If it is a cross tee fitting without a baffle you are getting throw over across the fitting and it will not stop. The only fix for this is to replace the fitting in your drainage system. In Illinois it is a code violation to put this type of fitting in that application.
When these power flush toilets come out it made this problem worse. In short there is no fix for this problem other than redoing the drainage system.
