Question about SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE SHOWS "0F" ON CLOCK OUTDOOR TEMPERATURE DISPLAY. BATTERIES ARE FRESH NOTHING HAS CHANGED. IT IS CURRENTLY ABOUT 80 DEGREES OUTSIDE. SORRY, I'VE LOST MY INSTRUCTION MANUAL.
    Problem Solver:
  • 7 Answers
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
  • Rusty Garrett Feb 03, 2014
    Didn't work thanks anyway.
SOURCE:
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Outside temperature not working on Atomic Clock (was working last night). Changed the batteries in both the outside transmitter and the clock tonight. Clock reset within minutes, but the outside...
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | SkyScan 86709 Atomic Wall Clock
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
Skyscan digital wall clock just quit showing outside temperature
you probably need to 'pair' the outdoor sensor with the main base: look for a 'channel' button, as these units usually can get information from several sensors and differentiate them by a channel number.
May 10, 2010 | SkyScan 86742 Digital Atomic Wall Clock
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperature won't work
Also,
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Changed batteries
Also,
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
974 people viewed this question
Top SkyScan Home Experts
Dave Robertson
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
