Just purchased Serif Complete Arts & Crafts Creativity Suite which will not install using auto run or through My Computer. Tried another computer to see if first computer was working ok. Software would not install on second computer either. My computer has all the system requirements as outlined on your cd packaging. Please can you advise how I can get this cd to install?
Question
My computer meets all the minimum system requirements but when I try to download the LeapFrog Connect Application, I receive the error message "Your computer must meet minimum required System Configuration"
Answer
Please make sure your monitor resolution is set at 1024 X 768 pixels or higher and then try to download the application again.
Computers allow us to connect with people from around the world, and successfully complete school and business work. Unfortunately, technical issues can arise after prolonged use of a computer or due to manufacturer issues. A computer fan that runs all the time can be from your personal habits when using your computer. Fortunately inexpensive steps can be taken to resolve the matter.
ventilation b> If you are using a laptop computer in your lap or on a cloth for an extended period of time, your computer may be overheating, causing the fan consistently run. Since the computer has little insulation between the surface and the motherboard, the fan stays on. Purchase a cooling pad for the laptop. It can be found at your local office supply store. If you don't want to buy a cooling pad, you can periodically lift your laptop up and sit it on a desk, countertop or another flat surface. If your desktop is overheating, it could be because it is in a small area with little ventilation. Ensure your desktop is in an area that allows air to circulate. How to Properly Clean Your Desktop Cooling System & Fanhttp://www.youtube.com/watch?v=GgOaIJ82gFM b> Dust b> You computer fan may have accumulated a lot of dust, which causes the fan to run continuously. Purchase compressed air and periodically spray the computer fan to loosen up any dust that may have accumulated. Most computer fans are exposed, so accessing the fan should not be a challenge. Technical issues b> In some cases, your computer may have either a defective fan or thermostat. Computer providers, such as Dell, allow you to purchase a new fan and replace it yourself. For thermostat issues, you may have to contact a computer repair professional for assistance. Computer is overworked Depending on the age of your computer multiple programs that are running can cause it to overheat. Watching a lot of DVDs, playing video games, and listening to music on your computer also can cause overheating. Considering closing some of your programs and rebooting your computer. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490Viruses or spyware b> Spyware can continuously run on your computer, causing the fan to overheat. Spyware is software that may have installed on your computer without your knowledge. Perform a virus and spyware scan on your computer. Download and install at least one of these all free depending on your operating system http://spybot-search-destroy.soft32.com/ Freeware detect and remove a multitude of adware files and modules. http://download.cnet.com/Agnitum-Outpost-Security-Suite-Free/3000-18510_4-75328020.html Combine online and offline malware defense and powerful data leak prevention in one suite. http://download.cnet.com/Agnitum-Outpost-Security-Suite-Free-64-bit/3000-18510_4-75328026.html For 64 bit operating systems Combine online and offline malware defense and powerful data leak prevention in one suite http://www.tomshardware.com/forum/11136-2-laptop-running-time-high Computer Fan Constantly Runs http://forums.techguy.org/windows-xp/533194-computer-fan-constantly-runs.html
ok what happened to it because you didnt say that so did it delete itself rir it stop working and you tried to install again answer this and i will help you
This is posted under Photoshop 7.0 for PC. If you are in fact using Photoshop here's what I would tell you. Photoshop is a highly professional bitmap based color correction, design, and illustration program. Since it's bitmap based it's a memory hog. It's recommended that you check the specs for the software and make sure you have at least the minimal system requirements. For any version of Photoshop you want at least 1G to 2G of RAM.
