It's a common problem in a OS upgrade. Is your OS 32 or 64bit? Is that the only thing that out of service? In Device Manager do you show ANY Unknown Devices? Is the Card Reader Listed? post results.
it might be a hardware problem,just don't try to push your card too hard into the reader, just slightly place it in reader. Or it might be your Card is Currupt.Have you tried to insert any other card ?
Get the external card reader and connect in desktop machine or laptop. Insert the SD card in external card reader and browse the SD card content in My Computer. Choose & copy the files, data, music files in local drive then paste the data in the SD card.
Hello bro.. Do you check your SD card? It is work ? My solution: 1. Off Lumix camera.Until LCD was off. Press center of card to remove it. 2. Use card reader to connect your SD card to pc/netbook/laptop.. 3. Check full capacity for SD card, it is empty(zero) or have it their mount. 4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal. 5. If still empty, that mean, your SD card was corrupted. 6. If not empty, backup all data in SD card. 7. Format the SD card using FAT32. 8. Checking Disk. 9.Insert back to camera, and format SD card using camera menu. 10. Take picture. and see if save on SD card or not. comment back here. if succes or not. 11. Don't use any battery except original from panasonic. It will affected to product. 12. Don't remove battery or card before lcd was off light. ---------------------------------------------------------------------
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter. If your Gateway laptop has a SD card reader: 5. Put the adapter into there.6. Transfer the pictures to you computer. Done! If your laptop doesn't have a SD card reader: 5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
That "5 in 1 card reader" is exactly what it says it is: a UNIVERSAL CARD READER. All you have to do is to insert the card into the slot and the machine will detect it automatically and will read it. The microSD cards should be inserted first into a microSD card adapter and after that the both should be inserted into the slot. As for downloading music right on the microSD card do like this: # insert the microSD card into its adapter [together should look like a regular SD card] # insert the adapter into the slot # the machine will detect the SD card [just wait until it is detected] # choose your song [mp3, wma etc.] # right-click on the song and where it asks whre to be downloaded you will choose MY COMPUTER > double-click > the letter corresponding to your SD card. You're done! Do the same with all songs.
GOOD LUCK! ... and don't forget to RATE, please...
1. First insert your SD card in the card reader.
2. Plug the card reader to your PC. 3. Go to My Computer, you will see the SD card as removable drive. 4. Double click in your card, and open. 5. Again go to my computer, open the a separate window. Open the folder containing your music files. 6. Select the required music file, right click, in the pop up window select copy. 6. Go to your SD card window, right click, in the pop up window select Paste. 7. You will see a window showing coping in progress. 8. After completed the process close the window. 9. Look at the right side of the task bar, there will be an icon, Safety remove hardware, left click, in the pop up menu select your SD card drive, one notification will come, "its safe to remove the hardware" 10. Remove the Card reader from your PC.
Hi Lavanya, Some machines can't read large capacity Sd cards my old Hp Nx6125 could only read max 1Gb. If your card is larger then you may need to purchase an up to date external card reader, most read up to 8gb and are not expensive. Hope this helped? if it does please remember to press the Blue button for my FREE effort! Paul 'W' U.K.
