There was a recall done on those vehicles in 2008 for the same issues. Something about a clock spring. If the recall work has not been done on your SUV, bring it to a dealer.
Sound like too much current going through the switch. Possible causes are bad motor, corrosion on the wire or contacts at the switch or motor, bad ground for motor, or excess friction in the window regulator. It can be any or multiple of the above reasons.
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Sounds like the beginning of vibration damage to the audio circuit. Need more info to diagnose more accurately. Contact us at Iron Cross Audio (www.ironcrossaudio.com) for more info.
