If there is power at the socket and if the plug fuse and the wire is intact then there will be power to the unit. The fault can be relative to the failure of the main program controller board / switch .
So use a multimeter to check the continuity of the plug to the main unit to confirm.
if so you might need to swap a board to confirm before ordering for one unless there is a minor fault on the board which can inpected with a simple test using the meter.
Thank you using Fixya.
