Try unplugging the unit for 10-15 minutes, if not TV need upgrade call authorized Sony service to do that ,don't waist money for new lamp,won't cure problem
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I found this on another website, most likely it is your power supply capacitors.
Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
Hi, Question shows tv is Sony KDF-60WF655. Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen. Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure. Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem. Did you replaced its lamp in last 2-3 years? Thanks.
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
KODAK Easyhare digital camera light status 1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure.Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light. 2.Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power 3. Blinking red light - Means camera batteries are weak or need replacement;If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board. via email? Thank you in advance for your help. Your help is much appreciated!
On my two channel radio a blinking green light means that it is scanning between the two channels. I can turn off the scanning and the light stops blinking.
