Press and hold the "Alarm
Set" button for five to seven seconds and the year will begin to blink when the clock is ready for
adjustment. . Set the year by pressing the
right-arrow, "Up" or "+" button, depending on your model of
clock. Set the month, day, hour and minute.
Press the "Alarm Set" or "DST" button to cycle through each
field, and use the "Up," "+" or right-arrow button to
adjust the values within each field. Press the "Alarm
Set" or "DST" button after setting the date and time to store
the information into your clock's memory. Press alarm 2 to change from Celsius to Fahrenheit. Press alarm 1 to change from 24 hr time to 12 hr time.
SOURCE: brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
SOURCE: how can I set the timezone on my Sentry
Many Sentry product manuals can be down loaded from the following URL
http://www.sentryindustries.com/support/manuals.asp
The instructions for Sentry CR104 is located at the following URL
http://www.sentryindustries.com/pdf/instructions/CR104_instructions.pdf
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
