SOURCE: "Disk is unreadable" message when inserting a CF Card - Macintosh OS 9.x
Certain system software is needed to allow a Macintosh (running Macintosh OS 9.x or earlier) to access mounted compact flash cards. If this required software is not installed the computer will not be able to recognize the card and will display the following error: DO NOT press the "Initialize" button, as this will completely erase the card and destroy all images. Click the "Eject" button and then enable the necessary system software. The following Extensions or Control Panels need to be activated: File Exchange - Control Panel Foreign File Access - Extension The "Extensions Manager" Control Panel (found under the "Apple" menu) can be used to enable these items. After switching them "On" restart the computer to apply the changes. After restarting the computer insert the card and it will mount on the desktop like any removable disk.
SOURCE: My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
SOURCE: Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
SOURCE: CF light stays on, cards come out unreadable by computer
You may need to have your camera driver and software reinstalled. It seems that the internal writer capabilities are corrupted.
This is evident if each card you use ends up corrupted or unreadable, but the rest of the camera operates normal.
