Nortel T7316E 2-Line Corded Phone Logo
Posted on Sep 03, 2008
Ringer Hello, I would like to know how to turn the ringer on, on my Nortel Business Series Terminal T7316E 2-Line Corded Phone. Thank you!
  • Anonymous Oct 03, 2008
    how do you turn down the volume of the ringer?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7685
Points
23
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
  • natmos Apr 29, 2011
    I can't find the "release key1" for changing the volume. Thanks.
3answers
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
HOW DO I CHANGE THE DATE AND TIME ON A NORTEL T7316E
You should complete programming on a T7316, T7316E, M7310, M7324 phone.
1. Feature **23646
2. Password: 266344
>>>Your password may have been changed by your phone company. Contact them for the password.
3. Select General Admin
4. Select Date and Time
5. Select Time
6. Adjust the Hour, Minute, and AM/PM
7. Press Rls when done
Meridian phone ringer too loud
You can adjust the ringer of your Nortel phone by dialing Feature *6, then using the volume bar to adjust the ringer while the tone is playing, or dial Feature *80 to adjust it there.
How to find my mac address for nortel t7316e
A T-7316e not having an internet CAT5 connection does not have a MAC address.
4helpful
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Nortel T7316E ringer
It always will. Now you need to go into system programming and program the phone to NOT ring.
2helpful
I need the template for labeling our T7316 telephone.
You can either download the business series terminal desktop assistant from nortel: http://www116.nortel.com/pub/swcode/desktopassistant/v1.4/DA1.4_setup.exe
or if you need the program and the paper inserts you can go to:
www.desi.com
1helpful
Require remote ring light for Nortel T7316E
What cabinet are you using? The CICS cabinet has an Analog Terminal Adapter built in (ext 117 or 37 iirc). This puts out a standard ring voltage that you could use to feed a strobe or relay. I hate to bring this up, but there is also an Auxiliary Ringer port on the sytsem. It's a make contact designed to handle 50 mA at 40v DC. You can drive a slave relay and switch whatever you want. It's assigned to a line or extension in programming. The only reason I hate to bring it up is because it makes your vendor look stupid, which he probably is. Carl
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
