Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Mod Logo
Posted on Aug 08, 2011
Same problem as Quest had on Jul 03, 2010. Remote shows degrees C and unit shows degrees F. So what's wrong? JWM
Dean Suhr
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 31, 2013
Dean Suhr
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1680
Points
9
Push the F/C button on the back of the home unit to change what units it displays.
Where is the fuse located for the braking system in a 1994 Nissan Quest minivan
Fuse 12 for the brake switch, but it covers a lot of other things as well that would be very noticeable.
Automatic Speed Control Device (ASCD) Brake Switch, Data Link Connector, Combination Meter, Heated Seat Relay, Park Neutral Position Switch, Display Unit, Steering Angle Sensor, Display Control Unit, Navi Control Unit, Back Door Control Unit, Sliding Door Control Unit RH/LH, Sonar Control Unit, Daytime Running Lights, Hands Free Telephone
Nissan Quest (V42; 2004-2009) fuses and relays
Fuse Box Diagrams https://fuse-box.info > nissan > nissan-quest-v42-2004...
Here you will find fuse box diagrams of Nissan Quest 2004, 2005, 2006, 2007, 2008 and 2009, get information about the location of the fuse panels inside the car ...
Missing: 1994 ‎' Show results with: 1994
2helpful
2answers
I graphed Y=tan(x) on two TI-84 calculators and they're both wrong! one shows a straight diagonal graph, and the other looks similar to an ordinary tangent graph but it's wrong!
Check the angle unit. If Angle unit is set to degree and window is about (-10,10) for X and (-10,10) for Y, you get a straight line. See screen capture.
Use radians. Or if you use degrees, set Xmin about -180 and XMax about180
With radian units the graph looks as follows.
Check the calculator configuration.
3helpful
2answers
I bought my Haier HWR 10xc6 mid summer of last year. Used it for two weeks and it was fine. Didn't use it much as went out of town the rest of that summer. I turned the unit on last week and set the...
Hello, it can be a few things. 1) plugged air filter and evaporator coil 2) low refrigerant charge 3) the compressor is not engaging If you are willing to check out a few things i can tell you exactley whats going on with your ac
How Do I Set the timing on 2001 Nissan Quest ? is there a Vacuum advance ?
the timing is controlled by the engine computer. You only set the base timing at 15 degrees by loosening the distributor hold down bolt and turning the distributor until the timing light shows on the 15 degree mark on the crank pulley.
go here and read files
http://groups.yahoo.com/group/villagerquest/
1helpful
Ho can i get deg off the top of mt calculator i think it is making my answers wrong not all but some of them when i try to check my work
Maybe some of your answers are wrong, but I can assure you that it has nothing to do with the poor deg indicator sitting on the top of your screen.
The indicator is there to remind you that the angle unit is set to degree, meaning any number you feed a trigonometric function is considered to be in degrees, and that any value calculated by an inverse trigonometric function is in degrees.
If you prefer to work in radians or in grads, all you have to do is change the settings of the calculator.
To change angle unit:
Press [SHIFT][MODE] and choose
  1. 3:Deg for angle unit in degrees. Screen shows D
  2. 4: Rad for angle unit in radians. Screen shows R
  3. 5:Grad for angle units in grads. Screen shows G
The calculator crunches number according to your specifications. It obeys your orders. Only YOU know what you are supposed to do.
I suggest you look at the manual that shipped with your calculator. Lookk for exemples of the calculation you want. Make a note of the exemple numbers and check the appendix for the particular exemple. The appendix will show you all the key strokes.
Hope it helps.
Thank you for using FixYa.
I have a Goodman mini-split system with a remote control. When I set the remote for a certain temperature in the summer to 80 degrees, the unit reaches that but then keeps dropping the temperature another...
How far from the unit or room do you have the remote? remember the remote is the sensor, if it isnt near the unit it will not shut off! place the remote 8 feet from the unit and leave it there, if it doesnt shut off, it was installed wrong or is malfunctioning!
3helpful
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Top Oregon Scientific Measuring Tools & Sensors Experts
Dave Parker
Dave Parker
Level 1 Expert
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
