when you connect to PC if you can see the disk/camcorder drive in my computer, copy entire folders to your PC it will work. possible : Check /replace USB cable :without using sony software copy files from my computer. :if lcd not working, use the copy button from the camera docking unit
No, it's most likely a broken flex LCD cable. It goes through the hinge and brakes very often. You should contact SONY and see if they would repair this for free (if you're out of warranty) as it's a factory problem.
Hi! It's most likely a broken LCD flex cable which goes through the hinge. It's a common problem with these cameras. I repair them every day as I work in a Sony service center. If you're out of warranty, talk to Sony, maybe they are ready to pay half of the repair or something like that as I believe it's a factory fault.
After researching various flexible cable numbers from different posts, I found that the SR-200 uses a unique cable, FP-610, part number 187145711. This has been discontinued and replace with part number 187145721 (same cable also used in DCR-SR300).
If you are in doubt with your camera, just take it apart up to the point of seeing the ribbon cable. The part number is printed on the side.
