.This is in answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR
Use the 65 degree low pressure nozzle for soap. The nozzle is black.
I missed it in the manual..drove me nuts until I slowed down to recheck the manual..
Same problem happened to me after starting it on the 1st pull used it and put it away for months.The carb.has a single jet which is a very small hole that gets gummed up when its not ran for awhile due to the Ethanol that they put in gas.Ethanol adds moisture to the gas over time as it sits.After you take the Carb.off and you take it apart and clean it.There is only 4 screws holding the air filter on to get to the carb.which is held on by 2 of those 4 screws.Before you take it off the motor drain the gas out of the bottom of the Carb.by removing the screw in the bowl.To make sure this wont happen again do two things.1st is to add a Fuel Stabilizer called STA-BIL its red in a clear bottle.2nd dont turn off the pressure washer by using the switch,turn off the gas and let stall by running out of gas so this way your carb will be empty as you it for month at a time.I have been doing these two things since the carb.was clogged on mine 4 years ago and when its time to use it I turn the gas on wait a couple of minutes for the gas to flow into the carb.and it starts everytime I use it and always on the 1st pull.Good Luck I hope this helps you....it did for me.
SOURCE: Troy-Bilt pressure washer will not pick up cleaning fluid
put the washer on low presure it will pick it up then. doesn't make since but that is how they designe them. thay make a high presurre add on device i have seen them them in local home inproverment places.
