SOURCE: Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
SOURCE: Machine stopped in middle of wash cycle.
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: in the middle of a cycle, it has stopped and is
nf is NO fill
i would check your cold water line
take it off the machine and check the screen as well
no fill means it is timming out waiting for water
