If not draining will effect the spin cycle
What does FP mean on a Whirlpool washing machine? Whirlpool washing machine error code FP. Some Whirlpool washing machines may display the error FP. This error code means "drain failure". If your washing machine is displaying this code it should still have some water stuck inside.Jun 27, 2011
It occurs mostly during a spin cycle and clothes remain wet. Share it! Whirlpool , Washers. The "F06" fault code indicates a drive motor tachometer error. This means the control is unable to properly detect motor speed and the machine will shut down.Feb 26, 2010
In the instructions for different models of Bosch dishwashers, the e27 error is described as insufficient voltage in the electrical network. This means that if the mains voltage drops below 220V (or 110V in some countries), the dishwasher stops working, and the E27 error code appears.
For LG A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Power supply problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
