LG 42PJ350 42 in. TV Logo
Anonymous Posted on Aug 07, 2011
Need a code for lg tele to use the sky remote for volume ect. the model number is 42pj350
Anonymous
Level 2:
Sergeant:
  • Expert 254 Answers
  • Posted on Aug 07, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
254
Questions
Helped
66322
Points
740
  • Matt_Sweeney Aug 20, 2011
    Lol you wolly! They wanted the 'code' that you type into sky remote so that the sky remote would operate their Tv for volume / on off etc and not a link to by another sodding TV. Whiz my arse!
    *buy
2helpful
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
2helpful
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Remote control signal
check battery contacts in remote..dirty,,loose,bat needs changing
2helpful
2answers
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
1helpful
SKY REMOTE CODE FOR LG 47LG50
please follow the steps below:
TV
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Remote control setup
TV
RED + SELECT
TV
0056
try your volume button if this works press the SELECT button to save the code. if not press TV and then try the volume again. repeat this step until the volume works. then remember to press the select button to save the code
cheers
Little Dish Fitter
119helpful
12answers
How do I get the volume to work on my sky remote control?
I've just done this, guided by SKY but all you really need to do it....
Press Interactive button on remote
Choose option 5
Then choose set remote control, it should give you instructions and the correct cde fo ryou specifc tv
Good luck
x
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
