Hello
Check your TVs power supply regulator section for any loose sodering points in it. The regulated voltage comes from it is more thatn normal. Check out all the soldering terminals. It is best to resolder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjecent solder points. The fault symptom as reported by sony is:-Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Check for any short circuit in the secondary section of the SMPS power supply section. Check the horizontal output transistor for collector to emitter short.
OK.
