Washing Machines Logo
Posted on Aug 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
Anonymous
Level 3:
  • Maytag Master 1,902 Answers
  • Posted on Aug 07, 2011
Anonymous
Maytag Master
Level 3:
Answers
1902
Questions
0
Helped
533785
Points
5669
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
How do you run diagnostics n Maytag epic front loader?
How to Troubleshoot a Maytag Epic Washer Front Loader Tip Call Maytag for service if any of these procedures doesn't clear the code on the washer display.
Warning Maytag makes several models in the Epic series and operating instructions vary. For model-specific troubleshooting instructions defer to the user manual that came with your machine or contact Maytag support.
Each model in the Maytag's Epic automatic clothes washer series has a computerized processing unit that displays error codes on a digital screen when something goes wrong with the washer. These codes help Maytag service technicians diagnose the unit. If you know the codes, you can troubleshoot the problem yourself, rather than request a service call, possibly fixing the issue yourself and saving you some money in the process.
Long Fill (LF) or Drain Problem (F9E1) Error Code 1.Press the power button to cancel the cycle.
2.Unplug the washer or disconnect power to the outlet its using.
3.Turn the power back on and select the cycle you wanted and press start.
Washer Problem (F--E--) Error Code 1.Press power to end the cycle.
2.Open the door to check for excess water in the drum.
3.Press "RINSE DRAIN & SPIN" if there is still water in the drum to remove that excess water.
Suds Routine (SD) Error Code 1.Open the drum at the end of the wash cycle.
2.Remove the clothes from washer, carefully examining them for damage from the excess suds issues.
3.Review your detergent uses to ensure that you're using the recommended type of detergent and the correct amount as stated on the product's instructions.
NF code may tag neptune front loader!
www.fixya.com > ... > Neptune > Maytag Neptune MAH5500B Front Load Washer
Apr 14, 2009 - CODE IN MAYTAG WASHING MACHINE Hello & Welcome to FixYa NF error in yourMaytag is displayed due to no fill condition, when the washer tries to fill but ... SOLVED: Maytag Neptune MAH6500AWW '03 front ...
Nov 9, 2016
SOLVED: HOW TO FIX NF CODE IN MAYTAG ...
Oct 2, 2011
SOLVED: Machine is flashing nF code
Jul 13, 2011
Maytag Neptune MAH9700 Front Load Washer Nf code ...
Jun 21, 2011
More results from www.fixya.com
1helpful
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
My Maytag Front Loader Washer was reading sud on the digital screen and also reading F02. After a few days past by, it stopped reading that because i looked online and thought i solved the problem. Just...
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
2helpful
Whirlpool AWM9000 front loader Gives SUD on display then F02 and beeps.
it is a Long Drain error
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank You
1helpful
Error code F02 on Whirlpool Duet front loader
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
1helpful
F-02 error code on whirlpool front loader duet
F/02 Long Drain
1helpful
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
3helpful
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
