Goldstar DH4010B Dehumidifier Logo
Posted on Aug 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Goldstar dehumidifier model DH4010 that needs a replacement water tank. I don't have a part number and I'd like to order one. Do you have any information that could help me? Roger
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Aug 07, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2104010
Points
14643
The water tank is available online at http://www.appliancefactoryparts.com/search/partinfo.php?partsID=276540&modelsID=124794&typeName=dehumidifier
It's the same one that's used in the similar LG model. Which makes sense, LG makes Goldstar.
Hope this helps you and thanks for choosing FixYa.
Need a replacement cord for my dh65e dehumidifier I s it possible to buy a replacement cord and install it my self the cord got nicked and there was a short
If you're really careful and persistent, you could probably do it. The real key, is don't remove the old cord from the uni, until you have the new one, That way, you'll see which leads fit where.
Here's a link to where you may can find the cord. http://www.appliancefactoryparts.com/airconditioners/goldstar/goldstar-other-parts.html
I hope this helped you.
Need a new reservoir. one side (it being plastic) has "ripped". after just a little water gets in the reservoir it quits. will not run to fill to capacity
Cindy, all dehumidifier tanks are plastic. If they weren't they'd rust. If you want to replace it, you're looking for Part # 48380A20052. You can find it at the following link. Just be more careful, removing and reinstalling it.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=276540&modelsID=&typeName=dehumidifier
Hope this helped you.
Water overflows when filled how do I adjust?
Remove the tank and locate the switch and 'teeter' (that the tank sits on). Make sure the tank is able to move when filled. You will have to adjust the position of the switch to allow the filled (teetered) tank to shut the device off.
Is it possible for you to drain the water into a nearby floor drain using a hose?
Thanks for your question @ FixYa.com
1helpful
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
I have Goldstar modle # DH 305y7 it does not run
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
2answers
No cowater collecttion
I have a goldstar dehumidifier model #dh2510a. It runs but does not collect any water in the tank. I have pushed the tank up to the red button in the back. Is there a fuse or something else I can do.
2answers
CIRCUIT BOARD
I've replaced mine twice.  water pools under the board and shorts it out.  I raised the mounting points this time around.  I found the board at Appliance Parts 866-312-3498
Top Goldstar Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
