The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
