If the camera works OK, then the r7 means that you have room in your memory buffer for 7 more pictures to take ("remaining 7"). As soon as you take a new picture, it gets transferred instantly to memory compact flash memory, and again r7 will display. The instance when there is r6, r4, etc. is short lasting, that you would not notice.
Change you camera setting, let say for small size JPG, and you should see that many more files will fit in the buffer, as indicated by a larger number after the letter r.
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
The number after the "r" tells you how many more pictures you can shoot in the current burst before the buffer fills up and the camera has to slow down. If you're only taking single shots or short bursts then it shouldn't affect your shooting at all.
The r07 is just a display that tells you how many pictures you have memory for in the buffer. It's not an error code at all. It will change when you change resolution, since pictures at low resolution take less memory than at high resolution. On the D70s this number will go from about r04 to r11 as you go from RAW down to low resolution.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
