Make sure all fans are working that is the one in freezer and the one next to compressor ,also make sure that coils in front compressor is clean.
Fridge settings numbers are the smallest number 1 is the coldest for the fridge
freezers or the opposite so 1 is the warmest
check the freezer door seals
SOURCE: Abnormal cooling in freezer/refrigerator
ok, this is insufficient air flow causing the uneven cooling. the fan that has stopped may be dead. you can test the motor with a multi meter and voltage needle. i would also preform a break point test on the thermostat as well. make sure the compressor and condenser are ok. if the noise is coming for the compressor, you may have a bad compressor unit.
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
