Question about New Bright Toys
I have a 1985 New Bright Challenger II boat with dock and a trailer. But it came with a remote controlled semi-truck that hooked to the trailer that the boat sat on. I'm looking to find the semi-truck. I believe it was sold as a set. The boat(challenger II blue water), the dock, the trailer, and the semi-truck. Have you ever seen this and where should I look to find the semi to purchase it?
5 Suggested Answers
SOURCE:
SOURCE: I have a new EP Rashing Boat NO. 7000 (remote control) that won't run. I have charged the boat battery and have new batteries installed in the controller. On switches are on. Is there a way to chec
hello!Most ep boats need to be in water in order for it to run.you say te model is 7000 ,who makes it? NQD....?
Posted on May 07, 2009
  • 14 Answers
SOURCE: I believe my New Bright Holiday Express train set
Yes they do. I have the #380-2 Water Tank car (and the other 4 that are available) They run and operate just as the other cars do.
Posted on Dec 16, 2009
Testimonial: "Thanks for the quick reply. This will really help!"
  • 5 Answers
SOURCE: rc challenger aircraft carrier has a finger touch
You would have to take apart the remote controller, there's a couple of small phillips head screws on the bottom of it. Then you have to remove the little spring from the toggle that controls the forward function.
Posted on Apr 22, 2010
cyrus320
tape aluminium foil to finger contact.
Posted on Dec 25, 2012
Relay location
What is this trailer? Is it for a boat, utility, semi? Need more info. Basics- check grounds, connections, switches.
Oct 23, 2013 | 2006 Ford F 350 Super Duty
Trailer running lights
First fix the shorted trailer lights, then check the owner's manual all fuse info is in the manual. If you don't have the owner's manual go to the GM owners website and download a free one there in pdf format.
Jul 26, 2017 | 2008 Buick Enclave
How do i launch a 22ft birchwood ruiser and how do i get it out of the water when there are only 2 people present, one female
only assume your female friend can drive. stage your boat at ramp you get in boat, she backs down into water, you drive boat off trailer. if she has trouble driving with trailer then you dock up boat and go park. OR you could let her handle the boat. just repeat process to load.
Jul 22, 2011 | Boating
I have a 2006 GMC Envoy and I am having a problem with my passenger turn signal on my boat trailer. The brake lights and parking light work fine. The lights are LED. I have tested the plung on the...
is trailer lite fixture grounded good try and wiggle fixture when u hit signal. next try wiggle pig tail on trailer , still no signal. it must be wire from truck, trace back to connection and check all splices. to see if signal light works on trailer unhook pigtail and get a battery charger or another battery, connect a jumper from positive side to signal spot on trailer hook up. hook up ground as well see if light works if not its in the truck for sure.
Apr 01, 2011 | GMC Envoy Cars & Trucks
Do the 2009 Nissan Frontiers have a turn signal flasher? I had a 2'' ball hitch installed and when attaching the boat trailer to the hitch the trailer turn signals don't work. When they hooked up the boat...
check for signal ground,this is not a metal ground, use a test light or volt meter to see if they at plug before you plug in the trailer, you may need to rewire the trailer.
Mar 19, 2010 | 2008 Nissan Frontier
Rc challenger aircraft carrier has a finger touch which you can control the boat but take finger off an it stops any suggestions please
Dec 25, 2009 | RC Challenger Aircraft Carrier
I am looking at a cabin cruiser with the view to buying same. Have been told that it is a cut down version of a Challenger yacht (40) Is their such an animal? Don
It may be that the seller is referring to the Challenger 40 sailboat, which came with either a marconi or ketch sail rig. Compare the deck layout, photos at the bottom of page, and the specifications with the boat on:
http://www.sailboatlistings.com/cgi-bin/saildata/db.cgi?db=default&uid=default&view_records=1&ID=14024&mh=1
...then it is the same or similar, this may be the boat referred to by the seller. There are also go-fast power boats with the name Challenger, but not something that a re-make would produce a nice cabin cruiser from.
Jul 20, 2009 | Intex Challenger 3 Boat Kit
2007 Frontier with trailer lights problem
Most likely it is the relay which is built into the turn switch. Turn switch will have to be replaced. It is also good idea to replace the flasher as well. Make sure both bulbs are new.
Jul 13, 2009 | 2007 Nissan Frontier SE Crew Cab
I have an ipod touch 8G I purchased a Bose soundock II. The sound is great but the remote only controls the volume. I cannot change tracks, move through playlists and when I hit the off button on the Bose...
Bothe the docking station and the remote are useless I recommend you buy a universal remote control.For the Ipod switching off-it does'nt switch off reason being it has it's own battery and does not depend on the electrical power of the docking station.
Mar 06, 2009 | Apple Bose SoundDock Series II Digital...
Toys Logo
80 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
