Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic in the "Electrical Noise Filter" that looks warped, like it got too hot. Could this be a problem? We tested the power as this site recommended but are inconclusive.http://appliantology.org/blog/1/entry-70...
SOURCE: I have an LG WM0642HW washer. After a wash cycle
sounds like a loose connection either going to the main control board or a break in your power cord or the main harness has a fault in one of the connection locations to the main control the control is located under the upper control area this is also the schematic for your machine showing how to access the control area http://c.searspartsdirect.com/lis_png/PLDM/K0810327-00001.png this repair will require you to break out the multimeter if you are unable to visually see any misconnection I await your reply for any further questions Thanks Rick
p.s there is also a relay located on the power board and if you dont find any issue with the wiring it may just be the relay that is hooked on to the main control board as well. I await your reply
