You have to check the wiring of the Main speaker. By i means you have to check the "wire" for the main speaker from the payer to the speaker. If you have use 4 speakers then you have to check all the wire of 4 speakers. Because if any one of the wire touch to the ground (chase) any where due to the bad insulation the the player will not out the audio. It will sence the short with the groun and will switch off the ouput amplifier. My be the wire is touching some time that why its works for weeks and then go off. Also you have to chek the leads of the speaker is there is any conact to the ground (chase). Also check for any short between the speaker wires. If so this will happen. This will not affect the sub. That way its work perfectly.
ok
