theres usually two ways. from the mp3 settings you can delete all music. or if you dont have that option you can use your computer to format it. you plug it in and right click its icon, and click format.
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player/Ipod ------------------------------------------------------------------------ Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please do not forget to rate me, Thank You
Under windows explorer, click on the icon for the mp3 player. On the mp3 player, switch between the Usb and Mtp mode (The M button). You should see songs from both modes.
You should be able to access the mp3 player as a removable drive when connected to your PC. You can then go into it using the standard file navigation system and delete the audio files that way.
initailly there was a dev. sys config file or something of that nature on the GPX website like a year ago that would allow you to replace and/or access your music and/or the GPX mp3 player, however 2-3 years later they have fixed bugs and put out many other mp3 players so your luck of finding this file is dwindling. try it w/ and w/out batteries and try to go to win explorer as oppsed to "my computer"
You should be able to hook your mp3 player up to your computer with the USB cable. This will allow you to browser the directory where the songs are and delete or add new songs. Your mp3 player will appear in your computer as a removable disk. The songs that you put on your mp3 player need to be in mp3 or wma format. I also found the instruction manual for your product in pdf format. http://www.gpx.com/shop_ind.php?id=%20%20344#
The GPX MP3 Player will not recognize .m4a files. You must convert the files to MP3 files first. To do so, in iTunes, click "Edit, Preferences". Change the tab to "Advanced". Inside, there should be a second tab control. Change that to "Importing". Change the "Import Encoder" to "MP3 Encoder". Close those windows. Select the song you want to convert to an MP3, right click, and choose "Convert selection to MP3". Then, locate the file that was created, and put it on your GPX. If you want to convert your entire library, just select all files using Control+A.
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites. WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers. You can also format the player in Windows Media Player itself: Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything. -Tha Mp3 Doctor
