Harvey, there are problems with the front plastic pully slipping on the metal drive roller. It appears that the drive belt is slipping. Just make sure that you rule the pully out first. If after that the pully stops with the front roller and the walk belt, there are only Two different drive belts used, double check the part number. Usually I use a ratcheting strap to pull the drive motor up to the bracket, because the belt is so tight there is no other way to get the motor close enough to the bracket to get the 3/8" bolts to even start into the motor. If you did not severly struggle to install the new drive belt, chances are its the wrong one.
Matt
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/matt_8dbc24bf722649ac
