If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
You can get the Restriction code here
Theunlockspot.com and Unlock it from Network Lock. Follow the instructions and enter the code correct step by step...
Nokia 2680 SLIDE Unlocking Instructions
Warning : Do not enter any wrong unlock
codes on your Nokia 2680 SLIDE mobile phones. If you enter over a
certain amount of wrong unlock codes on your Nokia 2680 SLIDE mobile
phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2680 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2680 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2680 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2680 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2680 SLIDE
For this problem contact the service provider.........
SOURCE: RESTRICTION CODES
hi if you tell me what county and network the phones locked to and also the imei number i can give you the unlock code but i need this info so i can use the software to generate the unlock code
SOURCE: Hello, I havent been able to unlock this phone.
your phone is locked by nokia and the operating company so your phone will operate only with the sim and the number that defined with the operator but there is a solution called a smart sim card
6103b -- b mean it locked and special edition for the company by nokia
SOURCE: Phone restriction code
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: how to undo phone restricted nokia 3120 units
can anyone tell me how to undo the restrictoin on nokia 3120 please
