Dell Inspiron 1300 Notebook Logo
Posted on Aug 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell 1300 inspiron (2004) unable to switch to external lcd monitor upon boot up current laptop monitor too weak (brightness) to see and/or to acccess bios setiings, which keyboard keys to press pls? Jon
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Aug 06, 2011
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1404299
Points
12062
Fn + F8 should toggle between LCD, External and both, wait about 15 seconds between Fn+ F8 attempts
1helpful
Start directly on external monitor
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
How to start computer on external monitor
Toshiba = Fn + F5
Can the dell inspiron m5030 work with a projector
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
Dell inspiron display very dark, brightness turned all the way up Using external monitor works fine .
check your power settings in the display you probably have it set to be dim when not plugged in when battery is under a specific charge. hope this helps
2helpful
3answers
Dell Inspiron 1300 can't connect external monitor
I was having the same problrm for my dell inspiron 1300. It is not FN + f5. It is fn +f8. Notice the Crt/LCD...
Dell 1300 LCD issue!!
Before buying any more parts, attach an external monitor and if the display is OK then the problem is your LCD, if the problem is displayed on the external monitor the problem is the Video card. I believe the 1300 has an integrated Intel video adapter
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
