SOURCE: riccar model rad.7 upright (radiance). roller
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
SOURCE: need owners manual for kenmore progressive vacuum cleaner model 116
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0412323.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
