system light must flashing every second or one second . that is mean the system work correctely . but if the light was flashing rapidly , i think there is problem with system .
reset router , if the light keeps flashing , change the router
This router doesn't support parental controls, however it does have domain filtering which lets you block specific domains. To log into your router.
Open a command prompt.
Start, type CMD and press enter
Type ipconfig
Note the "Default Gateway", this is your routers address.
Type this address into a web browser address bar. (Ex: 192.168.0.1)
Log into your router, enter any username and/or password.
If you never configured one and it asks its probably one of the following. (admin/admin, admin/password) You can also google your model + default login and you should find it's default)
When you purchased your router, if It came with software then your going to have to use that. It should be as simple as opening the software, finding the setting and changing it. If not, your going to have to be an administrator on the network and go to network settings.
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link
router but the same principle could be applied to you with the correct
firmware. Its worked for me on more than a few occasions. Providing you
can ping the router via a lan cable then the chances of recovering it
are very high.
To Configure the rputer you will need it attached to a computer .and run the setuo disk ,once it is installed open the Internet explorer and in the address bar type 192.168.1.1 this will bring you to a login screen and the username and password is admin for both . once in you can set up securty on the network and anything else you would like .You have not specified Qhat you want to Configure so if isnot what you are after just make a comment on this page and I will Gat back to you ASAP
Make sure you are holding the reset button down long enough that it reboots itself and see if that helps. I have come across several times, where people have not held the button down long enough.
You'll need to reset your router if you can't remember the password to get into the settings. There should be a tiny button on the back that you can press with a pen or pencil.
Once it's reset, get on a computer that's connected to the router and type this address into the URL field:
192.168.1.1
This should get you to the settings. If it prompts for a password, try "admin" and leave the field blank.
