SOURCE: 2001 Nissan Altima - Seat Back stuck in the recline position.
where is the overload protection circuit for power seat of nissan altima 2001 , the seat does not move back and front let me know if i could do the seat move
SOURCE: The recline on my power seat stopped working
Sounds like a bad switch or motor. If it will incline, I am assuming it is the switch itself. Replace the switch, and it should work again.
I just bought a 2005 Nissan Altima that had the same problem. The motor was fine. I opened the switch and found that a trace on the small circuit board was cut/missing. I soldered it on the spot and it solved the problem. You can access the switch by carefully prying off the switch buttons, then the plate. There are two screws that must be removed so that you can pull the switch assembly out of the seat.
SOURCE: 2001 Nissan Altima front power seat does not move
needs a forward/rearward motor. it has two separate motors under the seat. very common and i replace them all the time. good luck
SOURCE: drivers side seat is reclined and seat won't go forward
That would be listed in the owners manual. If you don't have one go here and download it.
